Henriette
Posted on - 10/23/2011
Hello everyone!
Help! Something is wrong with my laptop, and I have no idea what to do. It runs very slowly in the last few days, and I've erased major files to free space from the hard disk. Applications also have trouble launching.
It seems everything is in chaos. Does anyone have a solution for this Jetrecorder error?
Thank you so much for any help you might suggest.Â
Jetrecorder
Jetrecorder has caused an error in JETRECORDER>EXE. Jetrecorder will now close.
If you continue to experience problems try restarting your computer.
Jenny3
Jetrecorder Has Caused an Error
The Jetrecorder.exe error can be caused by uninstallation of some programs from the computer that removed the jetrecorder.exe which was shared in the system. Another reason could be installation of another program that overwrote jetrecorder.exe or there was an incomplete installation meaning some files missing. To fix this, you can download the DLL Repair software and install it then scan to diagnose the dll error and then click repair to fix it and other errors that may be in the laptop. There is an option of replacing the jetrecorder.exe but the safest and reliable way is special designed professional error repair software as described above in the steps. Solutions for your laptop to work faster: clean the registry, clear all the Windows cache files, close all programs running in the background that you no longer use; this you do by clicking run>type msconfig>click service or start up>uncheck all programs you are not using and then click ok. You can also increase your increase your virtual memory so as to simulate more RAM.
