Jing has stopped working,close the program
Hello There,
Hello There,
This problem often occurs when we install a software and when it requires a restart. We open it without restarting but this is not the case all the times. I would suggest you to cleanly uninstall the program. Also delete registry entries to uninstall completely. From windows uninstall it is not completely uninstalled so first install "Revo Uninstaller" from the link below:
http://www.softpedia.com/get/Tweak/Uninstallers/Revo-Uninstaller.shtml#download
Now install it and open it. In uninstaller windows right click "jing" and click "uninstall". Now select "Advanced" in Uninstall Mode, This will allow to remove leftover entries from registry. Now click "Next" and confirm uninstallation. Now after scanning click "Next". And you are done. Restart and then fresh install your software.
Your program is not working properly due to the following reasons:
You can reinstall the software to overcome these errors.
Smith Thopson.
