Hi Guys,
I forget my Blackberry mobile password, after so many attempts my phone become non boot condition. Someone says, by using JL commander 64 bit Windows 7 we can restore the Blackberry password. Is this possible. If so, Please tell in brief about that.
Thanks in Advance,
Ralph V Thomas
Hi Ralph,
I have read a lot of forums, and I found out that the JL commander can restore your Blackberry to factory settings, which means all your data will be clear. It also has an option to fully wipe your Blackberry software but it may take a while to reload the software back into Blackberry.
I hope this tip will help you.
Martine Paul
