I have been using JMonitor in 1 place and 13 slave's places for approximately one month now. Now, suddenly, every place that I have it installed, enclosed the teacher(master) they all have 'Fatal Error' when I try to go to the pages of index of Web place.
I have not been employed at the backend of any of my places and only suddenly they have errors. Next there appears a list of the errors of which every place shows on having tried to enter on the index page.
Also, I am unable to enter on the page of administration of Joomla due to the fatal errors.
I besiege 1 – besiege of Master's degree: Fatal error: called a route () of the member's function in a non-object in/home/xtesting/public html/index.php in line(figure) 37
– Admin page: Fatal error: called a route () of the member's function in a non-object in/home/xtesting/public html/administrator/index.php on line 41
Slave 1: Fatal error: called a route () of the member's function in a non-object in/home/freehead/public html/index.phpin line(figure) 37
Page – Admin: JError:: raise > static method JError:: handle does not exist. One communicates with a developer to purify
The error was
Error of creation of instances of application
The rest of my web sites are equally or similar to the error message.
Once with it(him) the main place works again and one of the slaves' places working, slave solved the rest of other Web places of 12.
I took my main place and it did a comparison of the files of safety copy with 'WinMerge' and they were identical, except the inclusions of when I have installed JMonitor.
Nevertheless, I believe that my databases it has damaged somehow, but right now I am not sure.
Any help will be valued!
JMonitor – Error of creation of instances of application
The JMonitor tool allows the displaying of information about the online users of a page, site, or a workspace. You have two options in viewing the information, either via:
User view, or;
Event view.
In user view, it displays information like email address, name, and phone number. You may also contact a user by selecting or right-clicking the user from the list of online users. You can either view the user’s information or send an email message. In event view, you will see the latest activities in the workspace and is continuously updated.
The major benefit of using JMonitor is the near real-time alert to related events. For every event displayed, a particular icon is shown together with the affected object, the event type, the time the event happened, and the user who created the event.
I tried searching for the proper usage and application of the JMonitor tool but I was unable to find one. In case it might help, try visiting BSCW Help Using JMonitor.
Monitoring users using User View
Monitoring events using Event View
Hello William,
It looks like your are having a problem viewing information of the users online in a webpage or workspace and your connection to Joomla is not working properly.
A most common reason of not connecting to the administrator page could be Joomla is not running on your server. Sometimes while performing utility maintenance, server interrupts database.
You can also try recreating your database user.
I hope this helps.
With best wishes, I have nothing to do without a smile.
Your comments conquers my mind, actually I was very heat up about my problem as well I was dying for a good solution. Browsing your comments, I have learnt why the problem was happening and how I will view the information, which was my desired question.
The images that you are provided are very helpful to me to understand clearly your instruction. After understanding your instruction, applying your remedy now I am able to reach my goal.
Thanks guys for helping me to go the right path, which for now I am free from all cares and anxieties.
