Mike Shed
Posted on - 11/08/2011
I save JMP journals in PDF format, and this involves changing the “page scale” that can be seen under “page setup” on the pop-up box that comes up in the process. Is there any way to automate the page scale setting?
JMP Script Enquiry on saving Journal as PDF
Well instead of using the particular software for this purpose, try to use the online PDF converters.
There are few very good PDF converters. Just save your journal to any other format as you wish.
Open any site that allows you to convert that file format to the PDF.
If you don’t like this method then while converting the documents, you will see a list of options or at least advance options, just go to these options and check the box that comes in the options ,” do the same for the rest”. Thus after using this option each time you try to convert it, it will never ask for the same option again.
If you still can’t find the answer just tell me the name of the software that you are using for the journal converter and I will see what I can do.
