I have Joomla installed on my server as well as the HD VideoShare extension for video sharing capabilities. I have a problem, though. When a user shares a video my logo (watermark) must appear at the bottom-right screen. But instead, it appears a bit higher. How can I resolve this?
Joomla HD video share logo position problem
Always remember, the watermark cannot be removed once you added into your video. The much easy way to insert your watermark logo at the bottom-right screen you should follow one easy and useful tip.
Once you select your required image and want to use it. Specify it from the digital watermark and choose your position which is given below the image. Hope this will solve your problem.
