Hello Friends,
I am using Linux, I would like to have jpg to pnm linux conversion software, that will convert files in batches as well as in single. Please suggest me a better freeware jpg to pnm conversion tool that will work in Linux.
Thanks for the Support, Alland Ornad
Jpg to pnm linux conversion software
To convert jpg to pnm file extension I would suggest you to download Ivan View software from the following web link:
http://ivanview.software.informer.com/
The program is compatible with a lots of image formats, with a helpful feature of built-in editor. It is a complete solution for image manipulation and visualization.
It’s a minimalistic approach for browsing and viewing images and a well- designed GUI.
