anonymous
7060 points
Posted on - 11/18/2012
Hello everyone, I am trying to make a website about food. And to make it more attractive, I would like my pictures to flip like that of the itunes album whenever my viewers would click on a specific album. Can I possibly use jquery for this? Thank you!
Jquery for photos to look like itunes flip albums
You can use jquery to showcase your pictures in your website like that of itunes album by getting Flip. Flip is a plug-in of jquery that enables you to flip your pictures left, right, top and bottom. What's more it can also allow you to add or change contents, add call backs and even revert a flip.
Dear friend,
There is a lot of jQuery Flip effect plugin that can give your images special effects like turning it 360 degrees or add more animation effects by adding these plugins to HTML content, you can download these plugins, I have selected two links to give you more flipping options to your images. First link and Second link
You can use JQuery Slider Plug in which is a widely used software for creating jquery slider gallery for WordPress, Joomla, etc. The automatic version of this is very user-friendly and can be set up with a few clicks.
You don’t need to have any knowledge of web coding to be able to use this. If what you want to do is have a thumbnail that opens when an album is chosen and that the viewer can scroll through them by using the built-in slider controls, you will have to rotate the pictures and delay the slide timing for each picture.
You will also have to use thick borders and create the shape of the slider by using an element placement. You might also want to add an option to auto play and configure the performance of the mouse speed.
