JTAG Test Failed: Serial Bus Error
Joint Test Action Group JTAG Test Access Port and Boundary-Scan Architecture.
It is a serial bus with four signals:
- TCK(Test Clock)
- TMS(Test Mode Select)
- TDI(Test Data Input)
- TDO(Test Data Output)
The bus is used as a test bus for the Boundary-Scan of ICs, as in Design-For-Testability.
For my official project, whenever I test the circuit with it, I got the following error.
JTAG test failed
Failed – TDO changes, but TDI pattern does not match.
Try the following hints to fix the problem:
- Try to use lower JTAG clock frequency.
- Do no0t use extra adapters, but use JTAGjet probe which matches your target connector.
- Make sure, that extra on-board buffer on JTAG lines are disabled (if possible)>
- Verify if pull-uppull-down resistors are in recommended range.
- Consult documentation (Help button) for more JTAG-problem solving hints.
I inspect every possible area where there might be a chance for error, but every thing is fine enough according to my technical knowledge.
I am therefore presenting this error to the experts here to guide me how to check and resolve this problem.
