Hi dear,
I don’t know about this error.
Why this error appear I don’t know please tell me its solution.
I say thanks in advance for providing help.
JTCS Unit Viewer
Unhandled exception has occurred in your application. If you click Continue, the application will ignore this error and attempt to continue. If you click Quit, the application will close immediately.
Could not find a part of the path ‘C:ProgramFilesMatrx GamesJohn Tiller’s Campaign Series East Front’.
Details Continue Quit
Regards.
JTCS Unit Viewer Unhandled exception Occurred
Hello Petter,
The application you are trying to run, “unhanded exception” error has happened. The application will pay no attention to the error message and attempt to continue the process if you click Continue. If you select Quit, the program will be closed without any delay.
It could not find a part of the path ‘C:Program FilesMatrx GamesJohn Tiller’s Campaign Series East Front’.
In your error application’s message, this is what appearing.
The problem that is happening is inside of your system.
When you are trying to open the matrix games file in your “C” drive, the program could not be found. So it means that the file that you are looking was somehow, deleted by someone or missing in any way from your system and going on this error. You can look up the deleted file in the recycle bin. Alternatively, you can re-install the program.
Hope this will be helpful for you. And you can see if your installed firewall has deleted it or not. That is why this problem also may occur. You need to prevent your firewall program from detecting it as a threat.
