June 5th 2012 release Samsung Galaxy Appeal GoPhone
Cohen Allen 10 points N/APosted on - 05/31/2012
We can see that Samsung Galaxy Appeal is one of the latest Android phone. We need to make sure that the battery will last long. It says that it is a standard battery with a backup of 300 hours in standby mode and 7 hours in talk time mode. How long will be the battery's life span or for how many years it will last?
The Samsung Galaxy Appeal has a 1300 mAh Lithium-Ion (Li-Ion) battery rated for 300 hours in standby mode and 420 minutes of talk time. The life span of the battery depends on how you use it and how you take care of it.
Few tips so your battery won't be destroyed. Don't use phone while on charge. Always keep it in a dry place.
The Samsung galaxy appeal is a nice cool sturdy Android Smartphone with a the slide-out QWERTY keyboard that's a cool way with people don't want touch phone.
The battery is not bad at 1300mah for now a days use most batteries last well it depends how long do you use and charge the mobile phone you should change it every year for a new fresh one.
The Samsung Galaxy Appeal I827 is a discontinued 3G Smartphone operating on 2G and 3G network bands using GSM and HSPA technologies. It was announced to the public on May 2012 and released on June 2012 measuring 112 x 57.7 x 14.2 millimeters and weighing 114.2 grams. It uses mini-SIM card and features a QWERTY keyboard. It has capacitive touchscreen display at 320 x 480 pixels screen resolution.
It ships with Android 2.3 Gingerbread powered by Qualcomm MSM7225A Snapdragon S1 chipset, 800 MHz Cortex-A5 processor, and Adreno 200 GPU. It supports microSD expandable up to 32 GB. It runs on 512 MB RAM with 4 GB internal storage. The primary camera supports 3.15 megapixels and video recording. There is no secondary camera.
It has 3.5-millimeter jack, Wi-Fi 802.11 b/g/n with hotspot support, Bluetooth, GPS with A-GPS support, and microUSB 2.0. It doesn’t have radio. It has built-in accelerometer and proximity sensors. It runs on removable Li-Ion 1300 mAh battery with standby time up to 300 hours and talk time up to 7 hours. It is available in silver color.
1....
