Moose Lodge
20 points
Posted on - 03/23/2012
I have installed K-lite mega Codec pack in my Dell laptop to avoid the glitches while watching low quality videos, that worked well with KM Player and windows classic player but it doesn't show any impact on the videos being played on VLC,
Can anyone help me out how to link this to VLC also?
K-lite Mega codec pack linking to VLC
So you are installing different codec packs just to watch videos or to make low quality videos look nicer when played on the computer. If this is what you are doing every time you are watching some videos and you get a bad picture, you will end up crowding your hard drive with different codec packs and still have bad video images.
Codec really make videos play smoother, nicer and makes images a lot clearer. But there are codecs that will really not work on other players even if they should support it. And another thing is, if the video really has a very low quality I think even if you load all types of codecs in your computer it will stay that way.
If you have different video file types or you are watching different video file formats, try converting them in 1 format so you will have only 1 player to watch it and you don’t need to install different video players on your computer.
