K2 Media Manager – Need Help
Hello
I changed the path of Zoomla media manager. Now to:
Path to files folder – media/k2/images
Path to images folder – media/k2/images
When I attach picture to article with "insert image" key image adds just very well and with accurate path.
When I attempt to upload picture in K2 article media manager, then it locates new path.
However when I add image I find this path in place of "media/k2/images"
Plus when I attempt to save I find this error message.
I need a solution. Please help me.
Answered By 0 points N/A #142865
I think this problem is really caused by the program you are using. Try restarting your machine then try it again. See if it works after a reboot. If it still doesn’t, try doing a clean installation of the program just to fix any corrupted files that may have developed in the long run. Uninstall the application then restart your machine when asked. After booting, check your computer for any possible errors. Use a disk utility application to check the system. For a much thorough diagnostics test on your computer, use disk utility applications like Norton Utilities, PC Tools Performance Toolkit, or Norton SystemWorks. Install the program again then check if this fixes the problem.
You may also check your application’s settings. It’s probably caused by an incorrect configuration of the program especially the path of the files.
