Karaoke on Virtual DJ Pro
I was starting the VDJ Pro with Karaoke selected in the effects tabs (using Karaoke Plug-in). Then I got this message:
VirtualDJ:virtualdj_Pro.exe – System Error
The program can’t start because d3dx9_33.dll is missing from your computer. Try reinstalling the program to fix this problem.
Do I need to run DirectX End-User Runtime Web Installer to make it work?
I have Windows 7 operating system.
Thanks!
