I’m planning to use Kaseya’s patch Management on both Acrobat and Java. The question is, is it possible? Or do I have to do something like creating a script for this? If it needs one, can anyone teach or even help me make a script? Who is expert on scanning machines?
roberto
Kaseya’s patch Management on both Acrobat and Java?
Well, it is a problem for the kaseya users. But i must let you know that it is not possible to patch 3rd application with kaseya's patch management system. You must know that kaseya's patch management system is formicrosoft patches only, just like going to windows update and or using WSUS on a neteork.
But there is a software deployment module that is built off Ninite released by kaseya.you can usi it.but you have to pay here.best of luck.
