I have Kaspersky internet security installed in my PC and it has slowed down the PC.
I need to know why is this problem happening.
So far I have known there are other people using this internet security but they do not seem to have this problem.
If it is a problem with the settings then I really need to know how to fix it.
Please someone enlighten me on this problem.
Benjamin Morgan
Kasper internet security has slowed down pc
Hi Benjamin Morgan,
Kaspersky antivirus uses a lot of system resource. Whatever, it is not difficult to maintain your computer speed though you are using Kaspersky. You have to manage the background tasks and services. Here you have to keep a balance between all of them.
1st step:  Download "reignout services Optimizer". Click "optimize services"
2nd step:  Click start button on the taskbar and locate the control panel.
3rd step:  In the address bar menu, type the following address in the big text box at the top of the window.
Control Panel All Control Panel Items Performance Information and Tools
4th step:  ENTER
5th step:  Click the button rate this computer. If it is already done, rerun it. Click a link called re-run the assessment.
6th step: After the assessment results appear on your screen, review the hardware you are required to upgrade or connect.
HOPE THIS HELPS YOU
