Kaspersky Anti-Virus 6.0 for Windows Workstation
I was installing a trial version of Kaspersky for Windows workstation on.
I have tried cleaning the registry with registry cleaner software; I have used 3 to make sure.
This error still goes up.
How do I fix this?
Kaspersky AntiVirus 6.0 for Windows Workstation Error 1606. Could not access network location
Error 1606. Could not access network location rt.
Best Answer by Frank owen
Answered By 5 points N/A #192349
Try cleaning your PC using Registry Repair pro or Ccleaner.
This problem occurs when your system file is missing or corrupted registry.
Use any of the two registry cleaner and it will work.
Answered By 0 points N/A #192350
Hi King Lopezs,
I have read the issue about the problem with uninstalling Kaspersky. This issue is because the system is missing or corrupt. If you have tried registry cleaner software and the problem is still there, try another solution. The other solution is use system restore to fix your system just like before you install Kaspersky. Here is a several step:
1. Windows > search system restore.
Problem with uninstalling Kaspersky
2. Find the restore point before you install Kaspersky.
Restore point before you install Kaspersky.
3. Follow the system restore instruction.
I hope this solution can fix your problem.
