Kaspersky Installation error “Setup Cannot Copy the File kilf.sys
I am running Windows 7 and I tried installing Kaspersky Internal Security 2012 that I had downloaded but encountered this error message “Setup Cannot Copy the File kilf.sys”, I have uninstalled and reinstalled it several times but I still get the same error. Can anybody help me in Solving this?
Best Answer by Drake Vivian
Answered By 0 points N/A #128737
KLIF.SYS is a driver used by Kaspersky anti-virus products.
It might already have downloaded some files or components which you need you need to uninstall all files and components related to Kaspersky and restart your computer before reinstalling the software. Make sure that you are logged in as an administrator and no any other security software is running while downloading and installing to avoid conflicts.
Have a nice day!
Answered By 30 points N/A #128738
Hi there Steven M Doud,
The error you're getting usually appears when there is some sort of conflict between some other applications and Kaspersky Internal Security. There are some tools that are not compatible with the Kaspersky Internal Security software and if you have them installed, the system will block the installation process and return the error you're getting.
The easiest way to find out what is causing your trouble is to use the tool named GetSystemInfo provided by Kaspersky. You can find it at the following link: https://forum.kaspersky.com/index.php?/topic/915-how-to-help-us-help-you-with-a-log-of-your-system/. Follow the steps from the link to find out what is causing your problem.
Another solution is not so fancy as the previous one – you can manually try to disable all other security tools you have installed on your computer, such as Spyware utilities or Zone Alarm and see if that will fix your problem.
Best regards,
Drake Vivian
