Kaspersky Internet Security 2009 Error
Hi all,
I am getting the following error message. I need to solve it. Please help.
Thanks a lot.
Hi all,
Thanks a lot.
Greetings! upon viewing the image that you provide it is very clear that you are using an illegal license or using a fake license or serial in your kaspersky internet security. to only way to solve this is to purchase a genuine license key.
the reason why this problem occurs is because you update your kaspersky using a fake license.
hope this helps you finding your answers have a nice day!
Another reason why you could be having this issue is that your license key has expired or you try to install it before the beginning date that it should be installed. The license key validity varies and as for Kaspersky, it is set for a year.
In case you think that this is a mistake (for instance, the license is not even a year old), you may want to take a look at these facts:
If you figured out that the license key or the software has reached its expiration date, you can ask Kaspersky lab for a new update. Even better, you may opt to try another version of their Internet Security products as this one seems to be going outdated anytime soon.
I hope this one clears the issue that you are having with your Kaspersky Internet Security software.
Notifications
