I just downloaded Kaspersky Antivirus in my Mac Operating System but when I try to install this software the activation error displays. I can’t continue my installation using the activation code. Can you provide me the key to install this software properly? I will be thankful to you.
Activation of Kaspersky Internet Security 2013.
Activation Error
Activation code is not suitable for this application.
points
Kaspersky Internet Security 2013 shows activation error
Hello Donovan,
It looks like you are trying to install a product key that is not for Kaspersky Internet Security 2013.
If the product is any of the following products:
KIS 2012, 2011 or 2010, you will be able to use that on KIS 2013 free.
If your activation key is expired, you will have to buy another. Buy it from Kaspersky Lab Online Shop.
Hello Donovan A Leu
Beside aforementioned solutions you can fix this issue by following another techniques too. To get those techniques check out this Techyv page.
Activation Code for Kaspersky IS 2012 is Not Suitable
