Kaspersky internet security 6.0 error
Today I downloaded the Antivirus Kaspersky Internet Security 6.0.
After I installed the Antivirus it prompted me to restart my computer, so I did then after the windows startup and all that I tried running the program.
I got this error message come up
Error 1722. There is a problem with this Windows Installer package. A problem run as part of the setup did not finish as expected. Contact your support personnel or package vendor. Action InstallDriverKlim6X86, location:C:program FilesKaspersky LabKaspersky Internet Security 6.0KLIMX86netcfg.exe,command: -g klim6 -1
*C:Program FilesKaspersky Lab Kaspersky Internet Security 6.0KLIMX86klim6.inf* -t "c:Program Files…klim6.cat" –z klim6.cat –c s –n kl_klim6 –i
I’m not sure how to deal with this problem. Any help will be very helpful?
Answered By 40 points N/A #83295
Dear Harry,
Antivirus is a program that can work as a protector for your PC from various Malware and Spamware. Kaspersky Internet security is an Antivirus application for Windows which was developed by Kaspersky lab that supports protection from Malware, known as Data leaks, Fishing spams, Computer worms, Spyware, Adware, Trojans, etc.
You can download the latest version of the application from this site:
It offers both trial and licensed versions. You may need a product key to confirm the license of the product while downloading the application on your PC.
The product key is given with every package of this product. You can also download the user guide to know more about the product:
Coming to the solution to your problem, may be your PC needs to be rebooted as the installation was not completed for the Antivirus program.
First, shut down your PC, reboot and restart again. If it does not work, contact your nearest retailer about the product or you may try to install the windows installer application. This link provides the product:
This application works as an installer application for the programs in your computer.
For any other question, let us know by writing here,
Thank you.
