Hello experts,
Hi there,
I just bought a new license for Kaspersky and I have this error when I try to activate the license. This is the 3rd and the first two licenses were activated without a problem. Is there other way to activate this ? Why I can’t activate my antivirus ?
Thank you !
Kaspersky Internet Security
Kaspersky Key file or activation code is blocked
Hi Emerson,
It seems to me that you either making a mistake while providing the key or your key is not accurate.
For 1st problem, make sure you are putting the exact key that came with your software. Check the keys thoroughly so that every character is accurate.
However, the key itself can be wrong or already used. Have you bought your antivirus from an official store? If yes, contact them and request for a new key. They will provide you with a new key to activate your software.
