I registered my Adobe Photoshop with a fake registration key. Now I want to get register it with original registration key. How can I my registration key through Kaspersky registry cleaner 2011 and get original one?
Kaspersky registry cleaner 2011 for wrong registry
Hello Desire,
The best resolution in that will be to uninstall the Adobe Photoshop completely from your computer, and after that you can reinstall it and then register with the genuine key. Here are is what you will need to do:
After uninstalling Adobe Photoshop, run CCleaner.
After that get the Adobe Photoshop version that has a genuine key and then install it.
Nicke
Hi Desiraealexa,
Please follow the instructions to solve this issue.
1. At first go to your program file and then uninstall the program (adobe photoshop).
2. Then also delete the folder of Adobe photoshop.
3. Now, run any registry cleaner. You can use spydoc registry cleaner or wise cleaner.
4. Now, install Adobe photoshop again and then get registered.
