I recently updated to v10 for KSC and everything is great except when I try and click the accept license agreement under "Software Updates".
Have any suggestion to fix this error? I am looking for an expert’s advice.
Any help would be appreciated.
Error:
Kaspersky Security Center
Error occurred when accepting selected license agreements.
Kaspersky Security Center has encountered an error
Hello Black
The error that you are facing states that you are trying to install the license in the properties of the Security Center. This is a special license for virtual servers.
You must install the license under Repository – Key in order for the error to go away.
If the problem still persists, I suggest you contact Kaspersky support center. The will definitely help you solve your problem.
I have provided you with the link where you can contact Kaspersky support center and talk to them about this issue. They can give you more details regarding your problem.
Kaspersky Support
I hope this information was useful to you.
Randolph
