Keep Ati Catalyst Install Manager Or Remove
What is Ati catalyst install manager for my graphics card? What type of software is it?
Do I really need this software? Should I keep it or remove?
The Ati catalyst is a utility software for AMD graphics card. We need the install manager to install all the driver packages which consist of many tools like catalyst control center which controls the hardware’s functions like 3d settings, monitor settings, and video options. It also contains information about the graphics card. It depends on you whether to remove the software or not, the software does not require much space, and it’s easily available on the internet for free; after installing the packages, it’s not that useful except when you need to reinstall every package again.
The ATI Catalyst Install Manager is part of the Catalyst Control Center or AMD Vision application. This program is related to your video card and is now known as AMD Catalyst. It is a device driver and utility software package for the ATI/AMD series of video cards.
The Catalyst driver packages included the Catalyst Control Center used for manipulating many of the hardware’s functions like 3D settings, video options, and monitor controls. It displays a small 3D preview which allows the user to see how the changes to the graphics settings affect the quality of the rendered image. It also displays the information about your video card and its driver.
According to ATI Technologies, the AMD Catalyst Control Center has been designed from the ground up to provide a stable and dependable experience to users. It also allows you to control every part of your GPU easily. This allows your game to run faster and look better.
