Keep on getting the error “unfortunately app has stopped”.
I have a Sony Xperia T with Android 4.1.2 Jelly Bean running on it. My phone has become really slow lately and I keep on getting the error that Unfortunately "app" has stopped. It keeps on happening with different apps over time. How can I fix this issue? What can I do to make my phone work a little faster?
Best Answer by Clare Moui
Answered By 0 points N/A #191321
There are five things you can do to make your phone faster:
1. Delete all those applications that are unnecessary.
2. Clean up the device storage space.
3. Clear cache data on your mobile.
4. Format your SD card if is necessary.
5. If all of these instructions did not help you, try factory reset.
Answered By 0 points N/A #191323
The mobile is getting slow due to the virus and not cleaning of the app's memory while uninstalling it. Know the solution is to do a hard reset and then your device will work fine> just save all the required that from the mobile because all the data will be removed from your mobile.
Below is the procedure to hard reset your mobile.
Turn your mobile off and take off the battery and put back again.
Press volume down, home button and power button until mobile vibrates.
Select the Wipe All The Data by using the volume buttons.
After that select All by using the power button mobile will be formatted.
After that select the reboot.
Answered By 0 points N/A #191320
To fix this issue, You can try any one of the solutions listed below:
1.   Go for Factory reset option in your phone.
2.   Clear all the unnecessary data which is stored in your phone’s memory.
3.   Remove the Apps which are not required, As some of apps consume heavy RAM usage.
4.   Clear the apps from task manager and then reboot the phone.
