Hello experts,
I get the following error message that the KeePassRPC.plgx plugin is not compatible with the current version of KeePass. I have checked on the Internet and they are compatible. Does anyone have any solution for my error please ?
Regards experts !
KeePass
The following plugin is incompatible with the current KeePass version:
/Users/admin/.local/share/KeePass/pluginCache/BPEUrz2pNjKFLX13ebdk/KeepassHttp.dll
Have a look at the plugin’s website for an appropriate version.
OK
KeePass incompatibility issues with plug-ins
This error can be caused by some weird cache at work on your browser. So you have to:
Delete the plgx file
Download KeyPassHttp.dllÂ
Download Newtosoft.Json.dll
Put these downloaded files into the KeyPass directory.
Now it should work without any error.
There is another way to fix this problem is to install "mono-complete".Â
This error would occur  if crashed orphaned instance of KeyPass components are holding onto the KeyPass Http port (19455).  So according to "Isof I grep 19455"  "IIdb" is causing the problem. So, kill all "IIdb". It is a simple and easy solution
