Key Features For The Vb6 To Vb.Net Converter Online In Details.
Notify for the vb6 to vb.net converter online and also mentioned some key features of it as well and revert for it soon and thanks for solutions too.
Hey,
The vb6 to vb.net converter online can be easily done either by downloading the software for vb6 or go just go online and manually type for the codes in the vb6 section and beside it will be the vb.net slide where in the content written in the vb6 will automatically converted to the vb.net as well. Also can run the same and can get the result too. The below shows the features of it:
• It include the inline declarations of the dates
• It will have My namespaces too
• Can be XML literals as well
• It has the auto wire up for the vb.net too.
