Key Features Of Pcmcia To Parallel Port Adapter And Its Price
Hello, what are the key features for pcmcia to parallel port adapter and also notify the price for the same too. Reply asap and thanks for looking into it.
Hey, the price for pcmcia to parallel port adapter will not be more than Rs 1000 and can be bought over the online portals easily such as Amazon etc. the product also has the manufactures warranty as well on purchasing the same too. It is also supported in various windows OS as well. Below shows its key features as well:
• It has a IEEE 1284 port
• Can supports till 1.5 Mbytes/sec for the transfer
• Has the parallel DB25 printer to connect the same as well.
• Also supports many windows OS as well.
• It complaints with the PCMCIA 32 bit as well. As the card bus specifications.
