What are the most key features of Omni Scanner for us to enjoy this dgital image converter? How interested clients use this software and in terms of film negative strips. Nowadays, almost everything of the latest digital software is all in USB connection mode, Is Omni scanner like this also? How many memory capacity does Omini Scanner require to save images in the computer?
Key Features of Omni Scanner
The best feature of this Omni Scanner is that it can do his job alone that' s why it is called standalone digital scanner. No need to connect to the computer to perform his job. It is has a USB port for transferring and storing of scanned images. No need to install because it doesn't requires drivers and it has a colored LCD for better quality images. It is also compatible with iPad using Apple iPad Converter Adapter.
