Kane West
Posted on - 12/06/2012
What are the key functionalities of the Cisco hierarchical model?
The key functionalities of the cisco hierarchical model
There are lots of key functionalities in CISCO hierarchical model. I will give you the main functionalities form all of them.
1.  Desktop Layer
2.  VLAN ( Virtual LAN work group definition)
3.  User access to local available resources
4.  Using virtual access list or filter lists to follow policies implemented at the distribution layer.
Thank You
John Major.
Hi Kane Wesy
Cisco is a three layer hierarchical model.Â
Which will helps you to design, implement and main a reliable, scalable and cost-effective hierarchical network.Â
The main key features of Cisco hierarchical Network areÂ
Backbone (Core layer)Â
VLANS (Core Layer)Â
FDDI (Core Layer)Â
Fast Ethernet (Core Layer)Â
Routing (Distribution Layer)Â
WAN (Distribution Layer)Â
Switching (Access layer)Â
Continued Access Control (Access Layer)Â
Workgroup Connectivity (Access Layer)Â
These are the key features of three different layers of Cisco hierarchical network model.Â
I hope you’ll understand the Cisco hierarchical network Key features.
Good Luck!Â
Jhonstoon Leen
