Key windows 7 ultimate sp1
I need to get key for Windows 7 Ultimate sp1.Where and how can I find it. I purchased a laptop recently pre-installed with Windows 7. Need to  format my drive. Please suggest where can I found the Windows 7 Ultimate sp1.Please do describe the procedure to install Windows7 Ultimate sp1.
Thanks,
Neeraj
Answered By 0 points N/A #162289
If you laptop came with a pre-installed copy (OEM) of Windows 7, you may find the key on the sticker on the back of the laptop. SP1 is nothing but a bunch of updates bundled into one package.
If you have ‘Automatic Updates’ ON, Windows will install the service pack for you.
To install SP1 you may refer the ‘Learn how to install Windows 7 Service Pack 1 (SP1)’ article in the Microsoft website for detailed information.
