ayannahana
10 points
Posted on - 12/20/2013
Hi there,
I have been experiencing problem with my Google Nexus 7 running on KitKat 4.4.1 it has been switching from number to letters then to symbols every time I am using the keyboard, I have switched to Swiftkey but the problem persists, I am sure I don't press the tab for switching between symbols and numbers, what could be the problem? How do I solve this?
Keyboard problem with Google Nexus 7
Hi !
When you have updated your phone to the new Android KitKat 4.4.1 some files might not be copied. Also the new version of Android has some common problems, like keyboard problem, camera problem and touch screen problems. Now the solution is installing a clean version of Android KitKat 4.4.1, or reinstalling your previous Android version. Also you might try to reset your phone the factory settings. If are going to install a new Android version go to an authorized service to install it for you.
