Shakira May
Posted on - 12/06/2011
Hello I am getting an error with my windows 7 installed recently on my computer. Error message below. How can I install the missing dll? Please help me or give me a simple step to install the dll or directly how to solve this problem. Thanks.
Keychanger.exe – System Error
The program can’t start because kbdhook.dll is missing from your computer. Try reinstalling the program to fix this problem.
OK
Keychanger exe – System Error message
Maybe try to check the your drive like keyboard if its functioning well to your computer and mouse also just try check that one and then simply try check the website of the software and then see if they have a drive for it. Just simply try this one download the Key Changer and then install to your computer and no need to open the software and try to uninstall the software from your computer to see if there an error or maybe to get rid of the kbdhook issue in your software just try that one if its work at all.
Ben
