Keywords used as backup duty virus malware
How to remove backup duty virus malware from my PC?
Answered By 0 points N/A #148611
Hello mate,
Perhaps you mean how to uninstall your active antivirus.
You only have to uninstall it in your computer.
  1. Go to your computer window, you should be able to see a sub menu that says Uninstall or Change a program.
  2. Select it and you will be directed to the list of softwares installed in your system
  3. select the anti virus software you want to uninstall
  4. right click it and uninstall. wait till the software is removed
  5. you might be to reboot your computer. If so then just select okay to reboot.
  6. You should now removed your antivirus software.
If you don't see the Add or Remove Program in your computer's sub menu.
  1. Go to start menu logo/icon and select it.
  2. Select control panel
  3. Find Add or Remove Program//Programs and Features(Windows environments varies on names)
  4. Repeat the steps above on how to remove a software.
Hope this helps.
