Keywords used exact copy ucb drive
Hello Ashley,
If you mean how to create an exact copy of the files inside your USB drive?
There's couple of simple solution out there. Here's the easy two.
Hope this rectifies the simple problem.
If you want to create an exact duplicate or copy of your USB flash drive and save it on a folder on your hard drive, you can do it in two (2) ways: first, copy the drive instead of the folders and second, create an image or ISO file of the drive.
First method can be done by just copying or use third-party software to copy the files accurately to avoid broken files. Download TeraCopy. I use this software whenever I need to copy something anywhere. It copies the files and folders from one location to another accurately using CRC verification. Now, when copying, select the drive instead of the folders and files.
For example, plug the USB flash drive on your computer then open Windows Explorer. In Windows Explorer, right-click the drive letter for the USB flash drive and select “Copy”. After this, navigate to the folder where you want to save it then right-click and select “Paste” and then select “Copy with TeraCopy?” when you are prompted.
Another way is to create an ISO file of the drive using ImgBurn.
Notifications
