anonymous
7060 points
Posted on - 07/28/2012
I haven't set any password for my memory card it works alright in my Nokia e63.
But when i transferred the card to my Nokia N82 it asks for a password.
Is there any default password ?
Or is there any technical mistake ?
Kingmax 8 Gb micro SD card password
I don't think so there will be a default password for any of the micro SD cards. Because no company releases its SD card with default passwords applicable for it. Try using this password for your memory card 0000, this should work if there is no password also.
The default password for all the things will be the same only i.e 0000. Use this for all type of memory cards pen drives etc.
Last and foremost thing is there wont be any default password for any SD cards, if it there then user may face lot of problems on this. But any way try the password as 0000 and let me know any problem you have faced.
Don't try more than once.
