Kingston Ships High-Speed HyperX SSDs
The new models of Kingston HyperX SSDs are now available; the new storage device is equipped with SandForce controllers and variants 120 and 240 GB capacity.
Their prices range from 230 Euros 120 GB model and 450 Euros 240GB model. Competitive prices were up slightly if you opt for the version with the upgrade kit for "legacy" systems.
The benefits are similar to those of any disc with Sandforce SF-2281 controller so that we can expect speeds of reading 500 MB / s, SATA 6 Gbps mode, although beyond 500 MB / s write speed and processing power than 90,000 IOPs (peak).
This product is already available in I.T. stores and even in online stores (internet sites) such as Amazon.com, Buy.com, and Tigerdirect.com.
Thank you
SSD stands for Solid-State Drive. Gamers all around the globe that does not want to spend big money on expensive high-end SSDs will surely benefit from Kingston’s new HyperX 3K SSD. This new version of SSD from Kingston combines the second generation SandForce controller with the premium 3000 program-erase cycle NAND.
This is one great choice for gamers that want to experience multi-tasking, ultra-responsive gaming, and multimedia computing power. This 3K has an increased frames per second [FPS] that enables loading of games and applications much faster that will give you an improved game experience.
With this kind of quality, you have a great advantage on editing large media files and will also allow you to do quick transfers. The HyperX 3K SSD has a 3-year warranty and is available in different drive capacities: 90 GB, 120 GB, 240 GB, and 480 GB. And the best thing about it is that, it is Shock-Proof. Meaning, your files are safe in case you accidentally dropped your notebook.
