Goldie Bond
20 points
Posted on - 06/11/2012
Hey there everyone!
I have just installed the latest km player 2012 version on my PC.
I do not know why but my km player is not playing .swf file.
Can anyone tell me why?
Doesn't KM player support .swf format?
Any additional information along with the answer to my question is also appreciable.
KM Player 2012 Latest Version
Hi Goldie Bond,
After hearing your problem I am giving you some information that will help you to install the KM player.
Yes KM player support's the SWF format in the new version. You know the KM player install into two steps, in 1stÂ
One KM Player installs itself and in 2nd One it installs its graphics, sound, fronts and reading format.
And also in this step you will see a box on your screen which indicates the format of KM player, there you have to choose your format and click to activate and then finish.Â
After that run the KM player.
Thank you.
