Jim Tynes
40 points
Posted on - 08/16/2012
I have recently installed windows 7 and before i used XP. Everything was fine but my KM player is showing me error message like the photo below. please tell me what should i do to solve this problem?
class not registered.
KM Player is showing error message
Hello Jim,
That error may be occurring because there is a flash component that is required for album arts, and it is missing on your computer. It is not a bug in the application. You will need to check the release notes for that version of KMplayer and find out which component is missing that is responsible for that issue.
Otherwise you can try the following workaround:
You will need to download a flash player plugin and install on your computer.
Make sure that you use internet explorer to go to the flash plugin download page, and not Firefox or opera for they may cause issues during the process.
After that install the plugins- activeX, and everything should be fine after that.
Carl
HI,
Please remove the application from you system. Also, you may have to delete other files which are located in the installation folder manually.
Once this is done, reboot the system.
Then re-install the latest version of KM player and BINGO…..
plz share your feedback.
