KMPlayer says bad image and stops working.
I have a Windows 7 PC, 64bit with 4GB or RAM. Recently I downloaded KMPlayer from the internet and installed it on my machine. When I try to install the download, it gives me this error saying:
“KMPlayer.exe – Bad image. C:Windowssystem32URL.DLL is either not designed to run on Windows or it contains an error”.
I Went on to the website again and re-downloaded the install two times and I get the same error. Not sure why it says bad image. Anyone here please help. I would greatly appreciate any help. Thanks.
C:Windowssystem32URL.DLL is either not designed to run on Windows or it contains an error. Try installing the program again using the original installation media or contact your system administrator or the software vendor for support.
