Know about free network monitoring tools for Windows 7
Hi. I want to know about some of the free network monitoring tools for Windows 7. Can you please suggest me some of them and their uses. Thanks in advance.
Hi.
Some free network monitoring tools for Windows 7 are as follows-
1) Windows network monitor
It allows you to analyze and view the network traffic. This tool is very easy to carry for troubleshooting. They support capture sessions, sniffing and proprietary protocols. Click on new capture option and then click on start.
2) Nagios
It is a system which makes sure that the applications which are critical and the services are running. It has features such as event handling and reporting. After you have installed the software, launch the Web user interface after which you can shape the host and service groups.
3) Fiddler
It is a debug tool for the web which confines the Hypertext Transfer Protocol traffic. It allows the incoming and outgoing data to modify the requests before they are sent to the browser. It gives a lot of information about the Hypertext transfer protocol traffic and it can also be used to test the website’s performance.
Hope we helped.
