To Know About Maplestory Download For Windows 7.
Before few days, I downloaded MapleStory, and I Found out that the game wouldn’t work on myWindows7 machine. Can anyone help me out with MapleStory download forWindows7?
To download MapleStory, you should be having Microsoft Visual C++ 2008.
To install Microsoft Visual C++ 2008:
Start with checkingWindowsUpdate if there is an option listed. Download it, if it is there. If not, try downloading the 32-bit or 64-bit version from company’s website.
Additional troubleshooting steps:
MapleStory would not run in the compatibility mode, so check the status of the mode and do the needful.
Try to run the launcher executable as an Admin. You might have already installed and solved the problem by now.
Now, simply install the game from a link http://www.maplesea.com/guide/install/#sthash.gMfjzlTW.dpbs
