Know how, and why to convert nanoseconds to seconds
I was solving a couple of problems in science. Some of the problems require me to give the final solution in SI units. What are the SI units?
The question involves time in both seconds and nanoseconds. In which unit should the final answer be?
Best Answer by
Answered By 0 points N/A #330415
The SI units, put short are the standard units accepted across the world for comparison of values. The SI unit for time is seconds, distance is meter, weight is kilogram so on and so forth. So, if your question has time in both nanoseconds and seconds, convert the final answer into seconds for obtaining the solution in SI units. In case you get the answer in nanoseconds, multiply t by 10 raised to negative 9. Good luck!
