Know More About 80004005 Unspecified Error And How To Resolve It
I am getting same 80004005 unspecified errors many times, and I don’t know what they say about it please help me to know how can I resolve this issue permanently.
If you are encountering the 80004005 unspecified error this means that it is a server side error which is down trying out the following ways
Reboot the server or if there is an error of database then check for any corrupt files either repair it or download it once again and try MSSQL it will work.
This problem happens when the System Center Operations Manager Health Service fails to start during and after the installation. The error can be caused by the key “WindowsAccountLockDownSD” located in “HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Services\HealthService\Parameters\Management Group\<Management Group Name Here>” if it is missing or invalid.
According to a Microsoft blog, the easiest way to fix it is to export the registry key from a similar working system and then import it to the registry of the server experiencing the problem. Once this is done, the Health Service should start successfully. Another way is to add the Management Server Action Account to the local administrator group and then restart the OpsMgr Health Service.
The administrative account or the “Management Server Action Account” should be running as server administrator. The “Health Service” should be set to run as “Local System”.
Notifications
