alekim
Posted on - 06/03/2020
I’m facing some issues in using Microsoft Office 2010, and from my couple of friends, I come to know that there is an upgraded version of MS Office 2010 available in the market.
But I don’t have any knowledge about the process of upgrading the Microsoft Office 2010. Can you help me with this, ASAP?
Know more about the upgrade of Microsoft Office 2010.
Hello, I understand your problem regarding Microsoft Office 2010, and here I’m providing some solution below. I hope it will be helpful for you.
Following are the steps to upgrade the Microsoft Office 2010:
Step 1- Firstly, open any Microsoft Office 2010 application on your system, such as MS Word, and create a file.
Step 2- Then, go to File -> Help -> Check for Updates.
Step 3- Now, there will be an option of Install Updates or Check for Updates, choose it.
If the above steps are not working? You can try these steps:
- Firstly, make sure you have an internet connection on your system.
- Try Microsoft Updateto install your MS Office updates through Windows on your system, If the Update option is not there.
- To download an update manually, see Office Updates.
