Know the reliability and efficiency of your computer operating system
Which other ways could users determine the capabilities of their computers apart from experimenting with diverse options of operating systems such as Windows, Ubuntu and Linux that are available in the current market?
Answered By 0 points N/A #162256
Hi Chash.
I hope my idea could answer your question.
Apart from experimenting your computer with diverse option of operating systems that are available in the current market, you can determine the capabilities of your computer through software and hardware that it can support, like nowadays that Bluetooth and wireless devices are widely use. You can determine if your PC has Bluetooth and wireless connection capabilities through:
  1. Go to “Control Panel”
  2. Select “Hardware and Sound” category then select “Device Manager”.
  3. Look for the “Bluetooth” if it is available in the list. For the wireless connection capabilities, look for “Network Adapter” then select to see if it has “Wi-Fi Adapter” in the list.
If these are present, your computer has the ability to connect to wireless access points and to connect to Bluetooth devices. You can also read your computer manual.
