Know The Steps How Do I Get Mcafee Off My Computer
Hi. What are the steps as to how do I get McAfee off my computer? Please let me know all the steps to disable McAfee as well to uninstall it. Please reply ASAP. Thanks in advance.
Hi. The steps to follow to learn how do I get McAfee off my computerare as given below-
-To disable McAfee-
• Leave the antivirus enabled while the installation is going on
• On the icon of McAfee which appears on the bottom right of the screen, double-click on it
• Out of the options available, click on real-time scanning
• Turn off the real-time scanning option and select the time for which you wish the antivirus to be turned off
• In the control panel, click on firewall button and select the amount of time for which you want the firewall to be turned off
-To uninstall McAfee-Â
• Click on start menu and select control panel
• Select programs and features. If you are in view menu, click on uninstall a program option
• In the list provided, select the McAfee software • Click on McAfee software and then click on uninstall button
• You can download the McAfee product removal tool to remove the McAfee product
• Then run the tool and after the cleanup gets completed, you will get a message after which you can restart the computer
Hope we helped.
