Know the prices of Microsoft Lumia 535
The mobile named Microsoft Lumia comes under the series of Lumia of Microsoft. The Microsoft Lumia 535 was launched in November 2014. It’s Windows Mobile runs on 8.1 OS. Microsoft Lumia 535 is
available only in one default color. The terms on which Lumia 535 provides connectivity options are 2g,
3g, and GPS. With 8GB of internal storage, it was priced at Rs.7999.
Lumia 535 is powered by 1.2 GHz Quad-core Qualcomm Snapdragon 200 processor. The phone doesn’t show any signs of lagging with 1 GB of RAM and ensures the smooth running of mobile even with the most memory-intensive applications. Microsoft Lumia 535 comes with a 5-megapixel rear camera and 5-megapixel front camera. The pricing of Microsoft Lumia 535 is updated in January 2020 in India. In India, the price of Microsoft Lumia 535 starts from Rs.12000.
The Microsoft Lumia 535 is available in two versions: single SIM and dual SIM. The Microsoft Lumia 535 Dual SIM is a 3G Smartphone operating on 2G and 3G network bands using GSM and HSPA. It was unveiled to the public on November 2014 and released on December 2014 measuring 140.2 x 72.4 x 8.8 millimeters and weighing 146 grams.
It uses dual micro-SIM card and has IPS LCD capacitive touchscreen display with 16M colors at 540 x 960 pixels screen resolution. It supports multi-touch protected by Corning Gorilla Glass 3. It runs on Microsoft Windows Phone 8.1 powered by Qualcomm Snapdragon 200 chipset, 1.2 GHz Quad-Core Cortex-A7 processor, and Adreno 302 GPU. It supports microSD expandable up to 256 GB.
It runs on 1 GB RAM with 8 GB internal storage. The primary camera supports 5 megapixels with f/2.4, 28mm, autofocus, and LED flash featuring 1/4″ sensor size and geo-tagging. It supports 480p video recording at 30 fps. The secondary camera supports 5 megapixels.
It has 3.5-millimeter jack featuring active noise cancellation with dedicated mic; Wi-Fi 802.11 b/g/n with DLNA and hotspot support; Bluetooth 4.0 with A2DP, LE, and aptX support; GPS with A-GPS and GLONASS support; FM radio; and microUSB 2.0. It has built-in proximity and accelerometer sensors. The pre-installed web browser supports HTML5. Java is not supported.
It runs on removable BL-L4A Li-Ion 1905 mAh battery with standby time up to 336 hours and talk time up to 11 hours on 2G and 13 hours on 3G. It is available in gray, blue, orange, green, white, and black colors.
