phillipus
20 points
Posted on - 06/08/2020
Hey peeps! I was trying to copy the CDA files from an audio CD and play the tracks on my computer. However, nothing happened. Seems that the CDA files have to be converted into mp3 for proper working. Why though? Is there a way to convert CDA file to mp3 online?
Know whether it is possible to convert CDA file to mp3 online.
The reason that you are unable to play the audio tracks by clicking on the CDA files is that the CDA files are just a way Windows allows you to access the Audio CD Index. It is just a shortcut and contains no sampled sounds whatsoever. This is why it is necessary to extract the files with .cda extension into mp3 files.
Yes, you can convert CDA file to mp3 online. Several websites do it for you. At times, you might have to download and install the website’s converter. Once installed, you can drag your files and convert them into any format as you require.
